Shift kit?? - Ford Powerstroke Diesel Forum
Old 02-09-2010, 03:40 PM
Shift kit??
i have a Shift kit From Superior (4r100) my tranny has 100K on it still works just shifts a lil sloppy (no slipping tho) should i go ahead and install this and will it help? i have a 85hp BD x Power chip on the way
Old 02-09-2010, 03:43 PM
subscribing, Cory how much lift is on your turck front/ rear?
Old 02-09-2010, 03:46 PM
4 inch in the front 1.5 in the rear looking for 350 blocks
Old 02-09-2010, 03:47 PM
That will look good. Leveld out, mine has 3.5 in the front and it was too much so i put another inch in the front. Bought the 3'' blocks off Ebay "Newton Lifts" and took out the 2'' ones/ Perfect now. Srry for the highjack bro!
Old 02-09-2010, 03:50 PM
wriott
Guest
Posts: n/a
sloppy shifting is most likly cause by line pressures dropping or clutches geing worn out... check to see if you have any clutch material in the pan... or put a pressure gauge on to see what line pressures are
Old 02-09-2010, 04:11 PM
ok i am when it comes to trannys? so you think i should start saving for a new tranny pretty much? but how would i go about checking line pressure
Old 02-09-2010, 04:12 PM
wriott
Guest
Posts: n/a
do you have a chip in it right now???
Old 02-09-2010, 04:19 PM
no i dont i just ordered one will be here in 7 days or so
Old 02-09-2010, 04:21 PM
wriott
Guest
Posts: n/a
go to a trans shop. they can hook a pressure gauges up and see whats goin on
Old 02-09-2010, 04:28 PM
ok ill do that do you think the chip will help?
