Duralast vs. National?
Need to replace axle bearing/hub assembly on 1 side.
In searching the various parts sites, I found a Duralast (Autozone) assembly for $150 which is a full $100 cheaper than National bearing and $150 less than Timkin.Truck does not see hard off road use and I sure could use the extra $100 to buy the inner and outer axle seals, studs, etc. So............. Duralast = Good, Bad, whatever? |
How much is it total. You can get these pretty cheap on the Internet now. Like 300 ish...
I wouldn't have a problem with the autozone stuff... |
Do they sell the assembly and seals as a kit somewhere? |
Yes, check out Your Premiere Source for Ford Truck Parts and Accessories they have kits with everything. Or you can do the ebay ones, I have heard of guys using those too...
What I mean is the total price of the hub? |
here is where they are at... it is tough to find stuff on that site.
Your Premiere Source for Ford Truck Parts and Accessories |
Thanks for the link Layson, but they are actually overpriced when you add it all up.
Nat. Hub assy - $250 Axle seal - $42 Studs - $24 O-Ring - $5... $319 PSShop = $350 If I get the Duralast take $100 off the $319. Just am not sure about the quality of the Asain made hub assembly. They do however come with the same 1 year warranty as Timkin or Nat. More than likely I will grab the Duralast and get the seals and hub studs from Ford. |
Then I would roll that route. I didn't think Autozone was even in the ball park for price...
