no start help.
no start help.....
-------------------------------------------------------------------------------- ok, did a fuel pressure check no pressure, so replaced fuel pump. checked again, 10psi pressure. WTF!! I can hear the fuel filling up the fuel bowl. I checked with fitting at back of fuel bowl top right. Is this the right one? changed out fuel filter. Now while I"m cranking, I notice alot of white smoke. Jody actually saw this also when he was over the other nite. Noticed that the rpm barely moved. Huh??? I thought I read a while back that if your cps is bad the rpm will not move.. I had this replaced with recall month ago. Go to my backup cps. same thing. How much will the rpm move? Any suggestions? When Jody did the scan it gave the following.. Checked the fuses all ok.... Swapped IDm relay with another of same kind no change P1670 EF signal not detected P07020 ouptut speed sensor circuit fault (think this was cause I tried to drive it while it ran like crap so had it floored to go 20mph.)? ICP 2200 rpm 292 cranking 3.37 fuel pulse width Thanks |
