sea foam?
I heard when changing the fuel filter I can add seafoam to the filter cannister? Just fill it up with the chemical? Will this hurt anything to run it straight like this?
thx |
yup, yup, nopee.
what does the seafoam do?
Cleans the crap out of everything it touches
it's good stuff, IMO |
thats the perfect response right there
should i drain the bowl and fill it with the old filter first? Then install the new one? Just add it with the new one?
Put it in w/ the new filter start it up and there will be soma smoke out the rear end
Thanks in advance for any info to this newbie
I'll take a stab at this one. I assume it would break down the molecular structure of the oil thereby not allowing it to lubricate/ operate the injectors properly.
well in power strokes (all but the 6.4) the oil is used (at very high pressures) to actuate the injectors and therefore inject the fuel ... so anything that lowers the viscosity or cleans (seafoam) or foams (lucas oil stabilizer) can increase your chances of messing up ur injectors and/or HPOP (high pressure oil pump) ... therefore making it a bad choice ... just do ur regular oil changes with a good, certified oil and youll be fine .. no need to worry about adding crap to clean out your crankcase if ur oil is changed regularly and u dont beat on ur truck
