A/C Compressor - Ford Powerstroke Diesel Forum
Old 04-09-2007, 04:26 PM
duct tape & zip ties
A/C Compressor
Ok yall I got something for you to help me figure out. No matter what position my heat control switch is in. Even if it is of the A/C Compressor Clutch still engages and disengages. I have no idea why. If the heat control switch is in the off position, the a/c compressor clutch should not do anything at all. My a/c and defrost work great but why is the clutch engaging and disengaging all the time when the truck is running.
Old 04-09-2007, 04:27 PM
Desert Shield/Storm Vet
Good question! My 99 ranger used to do that all the time, so will be interested in the answer
Old 04-10-2007, 10:56 AM
Not sure just why that is either, both my Fords are the same way...if the switch is on, regardless whether or not it is for the heat or a/c, it seems the a/c compressor is on as well. Annoying almost to the point of thinking about installing a seperate switch just for the a/c. I know that running the a/c does have a slight effect on mileage, but if ya don't need the a/c, ya might want that "slight" difference in mileage...I would..
Old 04-10-2007, 03:25 PM
all the car lines do that in one way or an other because in the winter months aka " don't need to be cold " they do this thur the PCM so the refrigant gets cycled so moisture doesn't build up in the system . also there normally pcm monitors the air time so can have a/c then its blow like 38 F .
Old 04-10-2007, 07:30 PM
I am with you on this. It is annoying as heck. Especially when you trying to listen for something that might be going on with the engine and you hear the dang a/c clutch engaging and disengaging all the time. I don't remember if it did it when it was new or not. I am just trying to find out if there is a problem with my truck if so I would like to fix it.
Old 04-11-2007, 03:25 PM
Powerstroke Techie
Send a message via Yahoo to gbear
see if this helps with the sequence of operation
Jim
Manual 2002 System Airflow Description.doc
Old 04-11-2007, 03:33 PM
Powerstroke Techie
You will notice that there are two type systems in these sheets.
The manual system and the Electronic Aotomatic Temperature Control or EATC type system
Jim
Old 04-11-2007, 03:35 PM
Powerstroke Techie
sorry for the typo in "Automatic"
Old 04-11-2007, 03:36 PM
Jim
That is good info but it does not explain how to fix my problem with my a/c compressor running when the heat control selector switch is in the off position.
