replacing front corner lites - Ford Powerstroke Diesel Forum
Old 02-04-2010, 04:38 AM
Is there a way to get to the phillips screwson the light bottom? One side(pass) is lower then the other. or the bumper is igher. I cant really get to the screws to remove the corner light. I have 2 trucks and both are like this on the pass side. I can get to the drivers side no problem. I got the job done but struggled and pried the light up and bumper down. I figure there must be an easier way to get to the bulbs?
thx
Old 02-04-2010, 06:05 AM
You won't believe how easy it is to relocate the bumper though. Simply loosen the two nuts next to the tow ring on that side, and the nut on the strut inside the fender (you'll spot it...) and the bumper moves up & down effortlessly
Then the two screws are easy to access....
Old 02-04-2010, 06:13 AM
thx, I see the 2 by the tow ring. But what nut on what strut? I see a thin 1.5 inch wide(approx) bracket on the inside. But that looks as if its just to the bumper and wont effect moving it??
Old 02-04-2010, 06:21 AM
Maybe that's right... I might have loosened it and didn't need to
Try it!
