2003 7.3 Block Heater - Ford Powerstroke Diesel Forum
Old 02-03-2010, 07:12 PM
Do all 250s have block heaters?? How do I know if i have one? I cant seen to locate a cord..
can someone maybe post a pic of where to look?
Old 02-03-2010, 07:53 PM
yes, you do, look under your bumper inside the valance(plastic part) on the left side of the truck(your right if you're facing it) should be a little plug with a cover on it. tucked under...
Old 02-03-2010, 07:56 PM
The block heater cord plugs into right above your oil filter. It has an orange end. If you don't see one there, then you need to order one from the dealer ($50). If you do have one there, then follow it and see where it leads.
Old 02-04-2010, 07:36 AM
cool thanks ill check it out when i get home,
so do all 250s have them?
Old 02-04-2010, 07:39 AM
IBEW Journeyman Lineman
I think all 7.3s came with the block heater and plug standard. It became an option on the 6.0s
