You can get Amsoil 75-140 for $11.70 a quart with preferred customer pricing!! |
F-350DRW 4.0L of 75W-140 full synthetic
I can't be the only one who read the spec sheet in the manual...it says Dana 80 take 75w90, so you have it right.
lol |
Sorry to hijack but I'm about to replace my diff juice and I would like to be sure how much I need, what rear end should I have and how can I know for sure? How much oil should I buy to do the front and rear? Thanks!
Here's all you need to know............. From AMSOIL 2000 FORD TRUCKS F350 PICKUP 7.3L 8-cyl Engine Code [F] Turbo Diesel LUBRICANTS & FLUIDS: Engine Oil Grade 1......CI-4 SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT) SAE 15W-40 Synthetic Blend Diesel Oil (PCOQT) Synthetic 5W-40 Premium Diesel Oil (DEOQT) Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil (HDDQT) -9 To 90F......10W-30 Above 10F......15W-40 Below 30F......5W-30 Below 0F......0W-30 Manual Transmission,S6-650 W/ COOL......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Manual Transmission,S6-650 W/O COOL......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Manual Transmission,S5-47......MA [1] Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Automatic Transmission,4R100......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Standard Differential, Rear Ford......GL-5 ALL TEMPS......75W-140 [2] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Differential, Front......GL-5 ALL TEMPS......75W-90 SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) Limited Slip Differential, Rear Dana 135......GL-5* ALL TEMPS......80W-90 [3] [4] SAE 80W-90 Synthetic Gear Lube (AGLQT) SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT) Limited Slip Differential, Rear Ford......GL-5* ALL TEMPS......75W-140 [4] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Standard Differential, Rear Dana 80......GL-5 ALL TEMPS......75W-90 [4] SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) Limited Slip Differential, Rear Dana 80......GL-5* ALL TEMPS......75W-90 [4] SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) Standard Differential, Rear Dana 135......GL-5 ALL TEMPS......80W-90 [4] SAE 80W-90 Synthetic Gear Lube (AGLQT) SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT) Transfer Case,......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Fluids Power Steering Fluid......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Power Steering Fluid......MA Torque-Drive Synthetic Transmission Fluid (ATD1G) Brake Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) Clutch Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) [1] Use only Synthetic Mercon spec. No ESR-M2163-A2 or equivalent [2] Synthetic oil is required. [3] Axles subject to frequent trailer towing in hot or hilly conditions may use Synthetic 75W-140 GL-5 [4] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent formulated to meet Ford Spec EST-M2C118-A for complete refill of limited slip axles. FILTERS: Oil Filter Absolute Efficiency Oil Filter (EAO99) Oil Filter WIX 51734 Oil Filter Air Filter Absolute Efficiency Air Filter (EAA728) [1] Air Filter INJEN-AMSOIL Air Intake Filter (X1023) [2] Air Filter INJEN-AMSOIL Air Intake System (PF9031P) [2] Air Filter WIX 46728 Air Filter [1] Air Filter WIX 46648 Air Filter [3] Cabin Air Filter WIX 24876 Cabin Air Filter Fuel Filter WIX 33818 Fuel Filter [4] Transmission Filter WIX 58968 Auto Tran Filter [5] Transmission Filter WIX 58967 Auto Tran Filter [6] [1] 3" Pleat [2] (Fuse reloc. Brkt) Cast Alum. Intake, ViT valves and dry filter. [3] 2" Pleat [4] If housing lid required, use 24232 - Available until inventory depleted [5] 4R100 - 4WD [6] 4R100 - 2WD NGK PLUGS AND WIRESETS: No Recommendations WIPER BLADES: Blade Class Driver Passenger ExactFit T201 T201 NeoForm T16200 T16200 Winter T37205 T37205 CHASSIS LUBRICATION: 2WD 4-10 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) Synthetic Heavy-Duty Grease NLGI #2 GC/LB (GHDCR) Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB) 4WD 0-7 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) Synthetic Heavy-Duty Grease NLGI #2 GC/LB (GHDCR) Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB) CAPACITIES: Engine, with filter..........15.1 quarts [1] Cooling System, Initial Fill..........32.8 quarts AMSOIL Antifreeze and Engine Coolant Automatic Transmission, 4R100 Initial Fill..........6.5 quarts Automatic Transmission, 4R100 Initial Fill..........6.5 quarts Automatic Transmission, Total Fill 4 speed 26 Plate 4R100..........17.7 quarts 4 speed 20 Plate 4R100..........17.1 quarts Manual Transmission, S6-650 W/O COOL..........11.7 pints Manual Transmission, S6-650 W/ COOL..........12.7 pints Manual Transmission, 6-SPD W/ OCOOL..........12.7 pints Manual Transmission, 5-SPD Mazda..........7.7 pints Manual Transmission, 6-SPD W/O OCOOL..........11.7 pints Manual Transmission, S5-47..........6.8 pints Manual Transmission, 5-SPD ZF..........6.8 pints Differential, Front..........6 pints Differential, Dana 50 Front..........3.9 pints Differential, Dana 60 Front..........5.8 pints Differential, Dana 135 Rear..........23.3 pints Differential, Dana 80 Rear..........8.5 pints Differential, Ford 10.5 RingGear Rear..........7 pints Transfer Case, ..........4.1 pints [1] When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase. TORQUES: Oil Drain Plug.....NA ft/lbs Manual Transmission Fill Plug 25-30 ft/lbs Drain Plug 25-30 ft/lbs Transfer Case NV271 Fill Plug 20 ft/lbs Drain Plug 20 ft/lbs |
