stock boost numbers - Ford Powerstroke Diesel Forum
Old 01-30-2010, 04:11 PM
stock boost numbers
I am looking to get a boost gauge, nothing fancy,
can i hook it (tee it in) to the rubber hose for vacuume that goes to the sensor?
also whats the stock turbo boost numbers supposed to be so i know if its right?
How high should the gauge read? Is a 35 pound gauge ok? 30 ok?
Old 01-30-2010, 05:16 PM
bump..........
Old 01-31-2010, 03:22 AM
anyone know the stock boost numbers? approx is fine.
Old 01-31-2010, 03:27 AM
I just installed my gauges ... my truck is purdy stock ... I have seen 18lbs when really hammerin' down ... hth
Old 01-31-2010, 03:45 AM
how high does your gauge read? 30 psi?
i guess i will do a 30 then if thats all it goes to.
Old 01-31-2010, 03:52 AM
yeah its a 30psi gauge ... "they" say it reads more true if you run in the middle of the range ... I almost went with the 60psi gauge until I heard this ... I am getting my PHP "FU" chip next week and will see what numbers that makes but really don't think our trucks will make more than 30psi ever ... time will tell
