Door Ajar Light on? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-30-2010, 03:38 PM Thread Starter
Phiber Optik's Avatar
Door Ajar Light on?
Sometimes when I know all the doors in my crew cab are closed the Door Ajar light on the dash will stay on and the interior dome light will stay on. I assume this is a door switch going bad or not making contact, where are the door switches and how can I service them?
Thanks, Jon
2008 F350 CrewCab ShortBox
Lariat
EGR Delete
Elbow
IC Pipe
4" SS Turbo back exhaust
4" lift with AirBags
17x10 with 37x13.5"
Tri-fold cover
Gearhead Performance Tunes!
Phiber Optik is offline
post #2 of 10 Old 01-30-2010, 04:56 PM
JJR
They are in the door latch and get dirty spray with wd-40 and see if that helps.
JJR is offline
post #3 of 10 Old 01-30-2010, 05:44 PM
ms8091's Avatar
Same thing happened w/ mine. I hit it w/ PB and let it soak, no problems since.
99 f 250 lariat 4x4 x-cab 7.3 --> SOLD
4" banks exhaust
AIS intake
zoodad mod
warn lockout hubs
285/75 16 Nitto Terra Grapplers
ms8091 is offline
post #4 of 10 Old 01-30-2010, 05:45 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
X3 same thing would happen to me, just spray em like the others said.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #5 of 10 Old 01-30-2010, 05:52 PM
Get Some's Avatar
Did the same thing on me. Like they said, spray them with WD-40.
2003 Ford F-250 Super Duty
6.0 Centennial Edition
2005 front end with
Harley Davidson Headlights
With 6000k HIDs
AFE Stage 2 intake w/Pro Guard 7
Autometer Cobalt blue gauges
Get Some is offline
post #6 of 10 Old 01-30-2010, 08:33 PM
millfire517's Avatar
I have this issue on my 2002, I just ordered a vehicle security module. I hope this fixes my issue. of course my keyless entry wont work, my auto locks and auto headlights are inop as well. not sure if a 2000 has that module or not but if the wd40 doesn't work atleast you have something else to look at possibly.
2002 F250 4x4 CC/auto.
Gone but not forgotten.
millfire517 is offline
post #7 of 10 Old 01-30-2010, 11:13 PM
WD40 will work-but I've found because it's made from fish oil andthat it tends to attract more debris back in becuase these switches point up-I've found a silicone spray works better-and it's also best for long reliabilty to remove the switches and spray clean and work them to make sure they're clean.
Nothing sucks more than having to do it all the time.
I've done this on many trucks and so-far-so-good. But do what you think is best for you.
icysmooth is offline
post #8 of 10 Old 01-30-2010, 11:24 PM
names liz <3 Camoprincess
famousamos0901's Avatar
Send a message via AIM to famousamos0901
icysmooth beat me to it.
wd-40 collects dust like a *****.
i also used a silicone spray, i also used brake clean and then made sure i lubed them up real good.
havent had a problem since then.
GOOD LUCK. =]
4" lift 35's with XD Spy's
AFE Intake
Full EGR Delete
Air Dog II system
ARP Head Studs
Pypes 7inch Mitre Stack
Bad Asz Ladies, Don't Drive Mercedes.
I love my country, I love my guns, I love my family, I love the way it is now, and anybody that tries to change it has to come through me, that should be all of our attitudes, cause this is America, and a country girls good enough for me, son.
famousamos0901 is offline
post #9 of 10 Old 01-31-2010, 07:25 AM
That is what ford said was causing my door ajar light, because the switches all worked fine. They wanted like $600 though to get a light to turn off....
famousamos0901
"33' LIBERATOR ALL TERRAINS"
You have 33 foot tires?
Austin G is offline
post #10 of 10 Old 01-31-2010, 07:30 AM
f250ghost's Avatar
That sounds like the dealer we have here locally...
Like everyone else...sprayed it with oil opened and closed it a few times and it was GOOD to GO!!!
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
