Need advice on wastegate - Ford Powerstroke Diesel Forum
Old 04-08-2007, 08:45 AM
Send a message via Yahoo to tocools
I unhooked mine last week and it did make a dif. But what I need to know is will it hurt to leave it unhooked? I have no mods I have a 99.5 auto with 185000 miles on it I use the truck for work pulling a trailer and to pull our 5th wheel.
Old 04-08-2007, 11:05 AM
Desert Shield/Storm Vet
No it won't hurt anything. The best thing to do is get yourself a boost gauge to monitor your boost. If you have no other mods you have nothing to worry about as your pcm will defuel the engine once it gets to 25 psi if you ever get there which you probobly won't without a chip or tuner. The red line applies pressue to the wastegate actuator to open your wastegate. With it not hooked up it just takes longer to open so you can build your boost faster.
Old 04-08-2007, 11:08 AM
Thank you I do like running it better I thought I mite get a warning that something was unhooked but nothing so know one will ever know but me
Old 04-08-2007, 11:14 AM
I would just add if you haven't already put the end of the red line over the bolt on the clamp for your intercoolers pipes. Just in case you want to use it again in the future the line won't be plugged up with gunk
