Quiet In The Cab - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-07-2007, 06:11 AM Thread Starter
PSDfan99's Avatar
Quiet In The Cab
Ok guys just a thought I had... I want to try and make my "in cab" quieter from outside noise, i.e. roadnoise, tires, engine. Dont get the wrong impression, I still love that turbo whistle and the roar of my exhaust, but I am looking for a way to make the inside of my truck more quiet. I have got rid of my stacks, so thats a step in the right direction (for me). I was thinking of undercoating my cab with something to give some added insulation so it can deflect or block some of that tire/ road noise that kills me on those long highway trips. Anyone got any good ideas or thoughts of what I could do to insulate the bottom of my cab with so I can reduce some sound?? Any and all welcome... thanks boys.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #2 of 14 Old 04-07-2007, 06:38 AM
The Fat Mod
Logan's Avatar
You could try to pull up the carpet, and put down some dyna mat or something along those lines. That is the same stuff that car audio installers use for sound dampening. There is something else that is similar, but don't remember the name right off hand.
Logan is offline
post #3 of 14 Old 04-07-2007, 06:49 AM Thread Starter
PSDfan99's Avatar
ya i was thinking of doing something like a bedliner or some form of undercoating on the under side of the cab, like the side that is to the road, not to my feet that way it would both protect and be a sound dampener, but the dyna mat sounds like a good idea.
Early 99 F-350
4" lift on 33's
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-ITP RR
-Jake
PSDfan99 is offline
post #4 of 14 Old 04-07-2007, 07:59 AM
Desert Shield/Storm Vet
vitalidle's Avatar
There is a door seal mod you can do. Use 3/8 id latex rubber tubing. Its the surgical tubing. You slide it in through the door seals. I think you need 50 ft for a crew cab. I haven't done it, but it seems to be a good cheap fix. You can find the tubing on ebay.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 14 Old 04-07-2007, 08:06 AM
wirenuts's Avatar
Send a message via Yahoo to wirenuts
how do i post a thread
wirenuts is offline
post #6 of 14 Old 04-07-2007, 04:02 PM
keystone crawler's Avatar
the audio mat works really well pricey let me tell you . the undercoating idea is good too look on the bright side helping fighting rust too. if really want to get into it you can use that audio pad on the firewall as well as the the floor ro help out .
99 PSD F250 DD / toy hauler
94 YJ 2.5 slow and not street legal anymore
keystone crawler is offline
post #7 of 14 Old 04-08-2007, 01:56 PM
lilredpowerstroke's Avatar
You could do the dynamat and get some expanding foam and start filling holes. You could also do the door seals but its not latex hose its the hard clear plastic type, just make sure you use lots of Ky or any other type of water based lubricant.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #8 of 14 Old 04-08-2007, 03:43 PM
im fat and ugly
stump0331's Avatar
found these pics of the door seal mod
2004 Excursion
stump0331 is offline
post #9 of 14 Old 04-08-2007, 03:44 PM
vitalidle's Avatar
Yeah you can use both, but I think for cold weather your going to want to use latex or it will be too stiff in the winter Thats for us unfortunate folks that have cold temps and snow 6 months out of the year! Darn the bad luck!
Auto 93,000 miles
DP Tuner F5
post #10 of 14 Old 04-08-2007, 05:43 PM
another thing i have found its called lizard skin paint type of product like undercoating supposely much better on sound
