Old 09-14-2005, 06:54 PM
nifty250 nifty250 is offline
more egt questions
i have a bully dog flip chip full 4 inch stainless exahust and a k & n filter what else can i do to reduce my egt so i can stay in it longer i was thinking a electric fan or nitrous or water spary bar on the intercooler im willing to take sugjestions thanks for the help
Old 09-15-2005, 06:45 AM
AYP Tires AYP Tires is offline
propane or water/methanol injection.www.snowperformance.net and BullyDog sells propane kits.
Old 09-15-2005, 09:02 AM
Andy Andy is offline
Administrator
Scotty's right. Cept I think Bullydog says that their propane systems will keep your EGT's about the same. The Water/Meth injection should get you down another 300 degrees however. And, if you are mixing the water with methanol, another 40 some horsepower from what I've heard.
Old 09-15-2005, 06:22 PM
could anyone give me a quick run down on how this all works im not to sure i under stand this is it a choice between wather and methonal or both and im not running more than 9 lbs of boost
Old 09-16-2005, 06:12 AM
http://www.snowperformance.net/ has the details. What are driving that has those mods with only 9psi of boost?
Basically it is an injection into the air intake at a recommended mix of 50% water and 50% methanol. Both components cool the aircharge and combustion chamber. The methanol is also a high octane fuel that increase the burn. It makes the EGT's lower and gives you 50-100HP. This kit is also a prevention for detonation they say.
Old 09-21-2005, 12:58 AM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
Cool
Hey Nifty, Ther right on the money with the three methods mentioned. all of them will cool the intake charge. Water methenol mix has the least HP gain. Nitrous can cause alot of heat to the pistons. Propane really complements diesel. They both burn slow. Your emission level will also decrease. The last item to reduce EGT's is a bigger turbo. This nodoubt is the most expensive but you don't have to fill it up and you can use it 7-24. The water methenol can run all the time if you have a big enough tank. The nitrous and propane are for short burst's only. I can run mine with a 14,000 gross weight at 40lb manifold pressure with about 850 on the pyro.
