How about these up pipe gaskets - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-21-2010, 12:34 PM Thread Starter
DJM
DJM's Avatar
Beans Diesel Performance - 94-03 Power Stroke Brass Up pipe Donut gaskets (Powered by CubeCart)
I can't realy afford bellowed up pipes right now. Anyone ever used these im sure they are better than stock but how much better it says won't have to worry about replacing again.
2001 Crew Cab, Auto
6in lift, 37Toyo's
DP F6 60eco,80tow,80eco,120
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
post #2 of 20 Old 01-21-2010, 06:10 PM
7.3powerstroke2000's Avatar
When I put my south bend clutch in. Their was black all over the tranny. Ran to auto zone, bought some regular donate gaskets (soft one) for around 4.00. Got more boost, quieter motor, and better fuel economy. Plus more power
I've never had another problem.
In God we trust
7.3powerstroke2000 is offline
post #3 of 20 Old 01-21-2010, 06:16 PM
no-tel-in's Avatar
haha, well glad it worked for you, I tried the chebby donut gaskets from napa and got so frustrated with leaks I now have the bellowed ones, and they are great.
But to the OP those look good, at least they wont disentegrate like my original ones were
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #4 of 20 Old 01-21-2010, 06:23 PM
duct tape & zip ties
bigcountrysg's Avatar
I also tried to install the chevy donut gaskets. For get it. The owner of the truck decided to go back to the original ones.
I also need new gaskets for my up pipes. I am looking at getting bellowed pipes. But I am thinking these might be worth the try.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 20 Old 01-21-2010, 06:32 PM
Austinj427's Avatar
I guess if you had some wicked long extensions or the transmission out, it would be alot easier.
I had to buy a set of bellowed pipes.
Austinj427 is offline
post #6 of 20 Old 01-21-2010, 08:10 PM
which one's would these be?? were they for the 7.3L or were they Chev ones??
BKraft03'7.3L is offline
post #7 of 20 Old 01-21-2010, 08:36 PM
Okiefromwatonga's Avatar
Send a message via Yahoo to Okiefromwatonga
I might have to give these a try as my up pipes are painting the heat shield black and are starting to leak enough I can heat them under power
2003 F250 SCSB 4x4 Muffler delete Stancor mod, ZooDad, Foil Delete
It is the Soldier who salutes the flag,
Who serves beneath the flag,
And whose coffin is draped by the flag,
Who allows the protester to burn the flag - Charles M. Province
Okiefromwatonga is offline
post #8 of 20 Old 01-21-2010, 10:01 PM
make sure if you use the beans ones you HAVE to use a torch to preheat them. you need to do this to expand them enough to even fit and then make sure you use alot of PB blaster or something after you have them on the pipe as you crank it down. this will allow them to smash as they are designed to do. someone on here didn't torch them to make them fit they smashed the hell out of them with a hammer and after all the hassle they ended up leaking anyhow. Beans diesel should have all the details on installation
post #9 of 20 Old 01-22-2010, 12:08 AM Thread Starter
DJM
DJM's Avatar
Well I think I will give them a try. I saw some copper ones on Ebay a few months ago for 60 bucks but they are not on there anymore. But hey 85 bucks hopefully it will last.
2001 Crew Cab, Auto
6in lift, 37Toyo's
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
post #10 of 20 Old 01-22-2010, 06:18 AM
djh
djh's Avatar
I used the chevy donuts from Carquest and they work great...a lot cheaper than those brass ones you are looking at. The Carquest gaskets seemed softer than the Napa ones, allowing more gasket crush and better seal around the pipe.
6637 DIY Filter
4R100 w/ Transgo Tugger and billet converter.
ISSPRO boost, trans, EGT on A-pillar.
DP-Tuner F5 chip: Stock, hi-idle 1200 rpm, 60 tow, 80 tow, decel, 60 eco, 80 eco, 100 performance, 120 race, 140 extreme, 140 aggressive
Wicked Wheel
djh is offline
