If its not one thing its another - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-21-2010, 07:24 AM Thread Starter
Okiefromwatonga's Avatar
Send a message via Yahoo to Okiefromwatonga
So I finally got the Stancor relay bought and installed, and its still a ***** to start in the morning if its not plugged in. So I noticed a diesel smell the other day when I was installing it but didn't see anything since I had just power washed everything. In poking around today I finally found the leak, its dripping out from the drain valve assembly into the valley. What I don't understand is can I be getting air in through this leak and if so how does plugging in the truck effect this?http://i989.photobucket.com/albums/a...k/101_1010.jpg
2003 F250 SCSB 4x4 Muffler delete Stancor mod, ZooDad, Foil Delete
It is the Soldier who salutes the flag,
Who serves beneath the flag,
And whose coffin is draped by the flag,
Who allows the protester to burn the flag - Charles M. Province
Okiefromwatonga is offline
post #2 of 19 Old 01-21-2010, 11:21 AM
This link may help you fix that problem. Give it a try.
Separator Valve Rebuild
mas360 is offline
post #3 of 19 Old 01-21-2010, 12:05 PM
addicted to diesel
highraven99's Avatar
theres another oring inside that can leak heres a link to another that shows the other oring: Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
New member map has been set up here:
Diesel fumes make me horny!!!!
Originally Posted by Big Angry Hillbilly View Post
I hear that Dodge gives you a puppy with every truck you buy, so you'll never have to walk home alone again.
highraven99 is offline
post #4 of 19 Old 01-21-2010, 05:34 PM
03_Turbo7.3's Avatar
man sounds like these are the least of your concerns..there cheap things to fix..they break its normal.. mine leaked too replaced it and all is fine..what are your temps like?
05+ coils, 10 Rear diff, box, tailgate, lights, bumper, Full 07 front harley swap...the list is endless.
AS IM RARLEY on here anymore...have a question ?? EMAIL ME
gladly answer any of your questions. OR search me on facebook. ill help out anyway I can !
updated as of OCT 28/2013
03_Turbo7.3 is offline
post #5 of 19 Old 01-21-2010, 07:37 PM
addicted to diesel
yes you can get air in threw the leak i was before i fixed mine 2 weeks ago. as for the plugging in and it being fine i cant explain that.
post #6 of 19 Old 01-21-2010, 08:19 PM Thread Starter
the fuel leak is fixed, got the o-rings from Diesel O-rings so no more diesel leak, but my truck is still a hard starter, I now have replaced the Glow plugs, GPR and under valve cover gaskets as well as under valve cover wire harness, why in the heck is it so hard to start? Do I need to start looking into Fuel pressure and HPOP pressures?
post #7 of 19 Old 01-22-2010, 06:00 AM
what temps are you trying to start it in??
post #8 of 19 Old 01-22-2010, 08:20 AM
E'sStrokr01's Avatar
Exclamation
"If its not one thing its another"
Ain't that the truth?!
And not to hijack the thread, but could this also be causing a rough running condition with my truck? If in fact air is getting drawn in where the o-rings are bad?
Thanks!
E'sStrokr01 is offline
post #9 of 19 Old 01-22-2010, 05:33 PM
could yes..just put new orings in it..hell the valve is dirt cheap from ford..i just bought a new one..
post #10 of 19 Old 01-22-2010, 05:57 PM
Austinj427's Avatar
When the truck sits, does the oil in the HPOP res. leak back down? I might let the truck sit for a few hours, go out there and pull the inspection plug and see if the oil has leaked down at all.
Austinj427 is offline
