tire sizes - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-18-2010, 03:55 PM Thread Starter
D3R3K's Avatar
tire sizes
ok i have the 235/85R16 tires on my truck now on the stock wheels, does anyone know what other choices i have to put on thoes rims?
99 F-250 4X4 auto reg cab
BMW tech
D3R3K is offline
post #2 of 11 Old 01-18-2010, 03:58 PM
Send a message via MSN to james7977
i have 315/75/16s on my factory wheels but they rub a little wen u turn sharp
james7977 is offline
post #3 of 11 Old 01-18-2010, 04:17 PM Thread Starter
D3R3K's Avatar
yeah, i just want something a little bit wider and mayber a little bit taller but not something i gotta put a lift on for
BMW tech
D3R3K is offline
post #4 of 11 Old 01-18-2010, 04:21 PM
smokenstroke's Avatar
Quoted: 8 Post(s)
You can fit 285/75/16's on there no problem. Every truck can run those. Some can run a little taller and wider. I had the 285's on my old 2wd and they didnt scrub.
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #5 of 11 Old 01-18-2010, 04:36 PM Thread Starter
D3R3K's Avatar
alright, thank you guys
BMW tech
D3R3K is offline
post #6 of 11 Old 01-18-2010, 06:26 PM
Fireman40's Avatar
Yeah I would go with the 285/75/16. Thats what I have and never had any problems. You can go bigger to a 305 or 315 if you want but then you tires tend not to lay flat on the road there for wearing them out a bit quicker in the center
2012 F-250 Crew Cab LB 4x4 OFF ROAD
BONE STOCK
Fireman40 is offline
post #7 of 11 Old 01-18-2010, 07:48 PM
i have 285/75/16 on mine right now and they dont rub. you should be good.
2002 F250
5in turbo back mbrp exhaust
k&n cold air intake
dp f6
with 80 tow and 80 econo for now
4in pro comp lift
foil delete
boost annihilator
boost and EGT guage
nboeger4 is offline
post #8 of 11 Old 03-22-2010, 05:01 PM Thread Starter
D3R3K's Avatar
how do they fit on the stock rims, are they all bulged out or do they look half decent, and any suggestions on what brand of tire? i was gonna either go with the BFG all terrain , or the dunlop radial rover RVXT
BMW tech
D3R3K is offline
post #9 of 11 Old 03-22-2010, 06:11 PM
Fred Swanson's Avatar
The 285's look just fine on the stock rim's they are what I run also.....Fred
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #10 of 11 Old 03-22-2010, 06:12 PM
I'm running the Yokohama Geolanders A/T
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
