Fuel water seperator
Is the fuel water seperator supposed to drain on startup. I have had the 2000 7.3 for about 5 years and never noticed it before (at least in the volumne that it has lately).
I have had consistent trouble with hesitation since getting it back from a transmission repair and think it may be a water in fuel fuel pump problem. Trying to figure out if it is a problemn at the seperator.
The fuel water seperator has a valve on it that has to be opened. It's a yellow valve on the rear of the filter housing. Is there fuel leaking from the drain valve pipe. IF so the drain valve o-rings are probably bad.
no its not supposed to drain on start up id say the orings need to be replaced. heres a link: Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
No only was it leaking on startup, but it pumped fuel when you turned the key to power (not start) and activated the fuel pump.
No replecement to be found at dealers or parts houses. Just ordered my new o-rings. Hopefully this will solve a lot of problems I was having that seemed like fuel delivery issues. It was being delivered and passed right through the separator onto the ground ![]() Not good for performance or fuel economy |
![]() I went out to the old green truck and pushed that yellow valve and do you know what happened. mmmmmmmmmmmmmNothing..... Don't suppose those rubber o-rings would help that. Thanks for your support |
I seem to remember
Back in '08 I had a problem where the housing had actually cracked causing fuel to seep/leak into the well on top of the engine. I suspect it was the below freezing temps. So, here we are two years later and I suspect I have been revisited by the evil spirit of the fuel/water separator. As I think back on it I don't remember asking about the frequency with which one should drain the thing.
Anyone have any thoughts on that subject? EDIT...I'm leaving the above as a testament to my underwhelming level of knowledge regarding things automotive. Yes I can build you a mansion but I am lacking from a motorhead perspective and should have read guzzle's stuff in the first place. With that said, let me ask for some insight. I didn't see anything in what I have read regarding periodic draining. I mentioned above about the filter bowl housing having cracked. I assumed that there was an "Excess" of water, which maybe I should have been smart enough to drain out as part of a regular maintenance program, that froze as a result of the extremely cold temps we were having at the time. Am I right in what I understand, short on information or totally out in left field? Last edited by cowboyjg; 12-14-2010 at 08:57 AM. Reason: Effort to remove the dunce cap. |
