Recon Cab Light Installation - Ford Powerstroke Diesel Forum
Old 01-15-2010, 03:47 PM
When installing recon cab lights on a 2001 ford f250 that has not had cab lights before, will i have to tap into another wire or will they just be plug and play?
Old 01-15-2010, 03:57 PM
there is supposedly a plug for the clearance lights under the passenger side kick panel. although some people are having difficulties determining which plug (apparently there are a few)
Old 01-15-2010, 04:51 PM
you can buy the plug and play harness from ford, but I'd just tap into the wire on your passenger side kicker panel. Mine had 2 wires going into it with nothing plugged into it. I will try and take a picture of mine tomorrow. You can also use a volt meter to find which wire. You will also have a ground wire that I just used the screw for the visor hook. Some drill it into the cross price
Old 01-15-2010, 11:07 PM
DJM DJM is offline
mine was right above the fuel shutoff switch behind the passanger kick pannel
Old 01-17-2010, 05:47 AM
thanks for the help, i installed them yesterday and couldnt be happier...
Old 01-17-2010, 06:20 AM
Pointless Poster
post up a pic
Old 01-17-2010, 12:14 PM
Would like to see a pic of the wire. Thanks.
Old 01-19-2010, 03:23 PM
will take better pic of whole truck when i have a camera, this was taken with my phone
Recon Cab Light Installation-19066_1148042663436_1298640985_30784183_1687772_n-1-.jpg
Old 01-19-2010, 03:25 PM
how do i post a big pic in the center of my message like smokinstroke02, just started using this website so im kinda learnin
Old 01-19-2010, 03:28 PM
Send a message via Yahoo to F250 Fever
welcome to the org!!!
