corner lights and towing - Ford Powerstroke Diesel Forum
Old 01-14-2010, 03:06 PM
does anyone know if you buy the stock clear corner lenses from 05's, will they fit into my 99? also can someone give me the towing compacity for my truck please
Old 01-14-2010, 03:10 PM
Feedback Score: 5 reviews
The 05 trucks have 1 pc headlights. The corners from the 04 trucks will bolt right in. As for the towing capacity, I'm not sure but someone should be along shortly to tell you
Old 01-14-2010, 03:42 PM
thank you, another question whats the split for 99 and 99.5?
Old 01-14-2010, 03:49 PM
wriott
Guest
Posts: n/a
in order for us to tell you what the towing ability of your truck is we need to know what your truck is...
Old 01-14-2010, 05:09 PM
99 f-250 7.3l auto 4X4 XLT
Old 01-14-2010, 06:14 PM
Then theres legal towing weight or what your truck will pull? lol.
Old 01-14-2010, 06:53 PM
well mine is an 02 350 & i can legally tow 20,000lbs & i max out or go over that just about every time i tow.
i think you will be fine with just about whatever you tow
Old 01-15-2010, 06:30 AM
on the door frame the sticker tells you the max axle loads you can have, and the max total truck weight, and then your trailer should have a rating on it. as long as you stay under 26k you don't need a CDL, go over that it's up in the air. Make sure you have good brakes all the way around though including the trailer.
Old 01-16-2010, 02:09 AM
alright, thank you guys
Old 01-20-2010, 09:03 AM
PS...welcome to the forum
