Removing pitman arm
Is there any easy ways to pull the pitman arm out when installing a lift.
I have a pitman arm puller but it just wont budge. if you use heat will it wreak the seal? Thanks |
theres a good chance you can damage the seals . beside your making the metal weaker be heating . sometimes gear pullers work better . soak in some pb blaster and use and puller when the puller is tright sometime smacking it with a hammer will break the rust and it all fall right off
Do you have a drop pitman arm you're replacing it with? You can go to AutoZone and they'll rent you a puller real cheap. I was working on a Wrangler one time putting a massive lift on it and we broke two rented pullers trying to get it off. After a beer or two I started thinking clearer apparently and realized I didn't need the OEM arm, so I took my angle grinder, notched a "V" in it and it weakened the metal enough to allow me to hit it with a hammer and it popped right off.
thats what happen on my wrangler what a PITA . went thur 3 pullers i end up cutting it off. i gave the splines a good coating on anti- seize
same thing happened here i broke the pos i rented at advanced auto parts and had to grind down the other they had in the kit and ended up taking a grinder to it to cut through the pitman arm.
Thanks guys. |
my pitman arm was an sob to get off also i ended up soaking it over night in PB blaster and then it took a lot of strength and one broken pitman arm puller to get it off lol....
don't know if anyone makes one but y the heck doesn't anyone make a pit arm puller out of some high strength steel or something... the ones from the auto place are made really poorly.....
yea you would think so.. i havent seen anything out there. but these small ones made in japan just dont cut it for full size pickups.
Yeah I'm with y'all - those things were a real POS. It wouldn't even budge it in our case and they just cracked trying.
