question about a regulated return - Ford Powerstroke Diesel Forum
Old 01-12-2010, 02:17 PM
addicted to diesel
i found this will searching for the regulated returns. its a hell of alot cheaper than most i see. if anyone knows anything about this one let me know thanks.
Dino Fuel Alternatives | Product Detail
Old 01-12-2010, 02:34 PM
I was looking at that the other day, I want it but I'm also unsure if its any good, BUMP
Old 01-12-2010, 02:41 PM
might head over to the Bio Fuel / WVO threads, lots of guys there know about DFA's stuff, I'm sure someone has used it
Old 01-12-2010, 07:47 PM
I just put one on my truck, Its a very nice kit, its not fancy but works well. Jason at dino fuel is A++, If you get one it does not come with a gauge ,there is a port to install one if you like I just hooked a test gauge up to check the fuel pressure after I installed it. It was at 55psi instead of 65 psi, So be sure to check it. Its a nice kit at half the price I did not follow the instructions ( remove brackets, belt, turbo, inlet hose) I just installed it and worked around everything, I didn't have bend grind or cuss its well made and fits.
Old 01-13-2010, 03:43 AM
addicted to diesel
Talmadge, where is the regulator on the kit, in the pic on there site i dont see one on it.
Old 01-13-2010, 01:11 PM
On the left side of the hose the (IN the pic) its the part that is black and has a silver fitting at the top, when you loosen up the nut below it turn the black body clock ways and it increases the fuel press
Old 01-13-2010, 01:34 PM
i know a lot of guy's running it and like it..its no DI or ITP kit..but gets the job done..keep hoses away from heat and places to chafe...like i said its no DI kit that comes with chafe and burn proof hoses..you can also build a kit just like the cck from napa..
Old 01-13-2010, 07:01 PM
do you guys find the trucks run better with this? im very interested also..
Old 01-13-2010, 10:07 PM
quites the injector rattle down and you can feel a little better power..
