Sterling 10.5 Rear Axles - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-12-2010, 03:12 PM Thread Starter
Fred Swanson's Avatar
Any known problems with these rear ends? I have a groan coming from mine....
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #2 of 4 Old 01-12-2010, 08:23 PM
Cj Ford's Avatar
likely pinion bearing, does the sound change with load on the driveshaft vs free wheeling ?
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #3 of 4 Old 01-13-2010, 06:53 AM Thread Starter
Seems to make the noise noticibly at low speed from take off, it also does it when setting on jack stands and putting in gear with no weight or load on it....can't hear it at higher speeds.....Fred
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
post #4 of 4 Old 01-13-2010, 06:56 AM Thread Starter
Also I can manually turn tire while on jack stands and hear it.
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
