i got it changed at 5 star ford. I know they changed it cause the truck slipped even in 1st when i test drove it. and they work on my fleet cars there so i got to pretty much check in every few hours and watch the tech change it out.
soooo..... is it possible they didnt change the fly wheel? maybe its scored? thanks for the input keep it comin.
by the way. reguardless its gonna need a stronger clutch.
should the stock clutch hold up? or should i just upgrade it?
Not sure, just make sure you get one that is rated for more HP than what you plan to make, that way if you get close to your ideal HP and add a new mod and go over that you will still be good on your clutch. :thumb:
if your just running a truck with intake, exhaust, and a chip how many hp clutch do you need? i know ill never go with turbo or injectors or anything big like that its to impraticle(spelling?) for me using this as a work/persional truck
i'll probably with with the 450/900 clutch kit for little over 700.00 thats a good price to have piece of mind.
so... guys how hard and long with it take me to change this clutch out on my 6 speed 2wd. I have 2 floor jack and a tranny jack. I also have all the air tools needed as well. so what do you think on time? anything i should know before i get ready to do this?
btw im going to video me driving around. i get lay rubbing to 60 mph without popping the clutch:nod:
when i get ready i'll hit you up thanks. send me a private message with your contact info. thanks
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
