Is this a LS diff? And which DANA - Ford Powerstroke Diesel Forum
Old 01-12-2010, 08:11 AM
So let's play a game. First one to tell me if this is a LS diff or not and tells me if it's a DANA 80 or what gets . . . a congratulations
Old 01-14-2010, 04:28 PM
anybody? maybe?
Old 01-14-2010, 04:34 PM
duct tape & zip ties
4.10 gear ratio limited slip. I can't tell if it is a dana 80 or not though.
If you look there is a decimal point between the 4 and 10 and then there is a ls on the bottom of the tag. I believe it is a dana 60 though.
limited slip and 4.10's im not sure about the housing though
Old 01-14-2010, 04:41 PM
Ok sweet. Knew it was a 4.10 just never EVER knew it was a LS. Sweet. How do I tell if it's working right?
It's a dually if that helps. Duallys are 80s right?
Old 01-14-2010, 04:52 PM
should be an 80 if its in a dually
Old 01-14-2010, 04:57 PM
Its a Ford limited slip so I doubt it is working.
Old 01-14-2010, 04:59 PM
Especially since I've never replaced the fluid since I've had it.75k miles or so?
Old 01-14-2010, 06:56 PM
The best way to tell if it's workingif you're stuck or not
Just jokin' around-but it's true!
Old 01-14-2010, 06:58 PM
Well that's true. I'm pretty sure it's not working. Wonder if I'll notice a difference when I change fluid
