Tranny Valve Body Replacement Question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-12-2010, 08:34 AM Thread Starter
In the Tech Files for the 7.3's, there is a write up called ----- Valve Body Install Write Up With Pics.
I assume the valve body is being replaced along with a new gasket.
Where do you find the upgraded valve body? Anybody got a sponoring vendor and part number , etc., So I can look into this a bit more ?
I am currently doing various oring replacements and turbo wheel replacement/rebuild plus a few other things. My 7.3 decieded to begin leaking all over the place.
I'd like to hit the upgrades in one major swoop once I gather up all the parts and pieces.
Thanks, Russ
XR-2001 is offline
post #2 of 8 Old 01-12-2010, 09:19 AM Thread Starter
Nerver mind--- I found the info on Guzzle's Website.... good info there.
RB
XR-2001 is offline
post #3 of 8 Old 01-12-2010, 09:36 AM
Tony V's Avatar
Well i'd call BTS if I was you and be done with it.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #4 of 8 Old 01-12-2010, 10:03 AM Thread Starter
Thanks,
BTS is the supplier that is mentioned on Guzzle's website. I'll give them a call and get things rolling. Being new to the performance diesel scene, I do not know the information such as vendors like you guys that have learned this info before me. But I'm learnin'............
RB
XR-2001 is offline
post #5 of 8 Old 01-12-2010, 01:42 PM
Powerstroke Junkie
NCHornet's Avatar
FTVB has been making tuned VB's for the 4r100 longer than anyone, as well as John Woods. Just make sure you follow the torque specs and pattern when you do it.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 8 Old 01-13-2010, 01:57 PM Thread Starter
Can the tuned valve bodies be used in congunction with a shift kits such as the Sonnax/Tricumulator Kit ? Or does the modified VB along with a good tuned chip take care of all the shifting woes?
Thanks, Russ
XR-2001 is offline
post #7 of 8 Old 01-13-2010, 02:02 PM
choupique108's Avatar
The tuned VB will not need the sonnax kit.
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #8 of 8 Old 01-13-2010, 02:02 PM
I see your from Louisiana. Check out the Lousiana Chapter.
