Long balljoint studs? - Ford Powerstroke Diesel Forum
Old 01-12-2010, 04:24 AM
Changed out my ball joints, went to put everthing back together and my ujoints hit the bottom ball joint stud. I had to grind 1/8" on the top of the stud to get the ujoint to clear. Anyone else ever had this problem. Yes they were cheap made in china greaseable balljoints.
Old 01-12-2010, 07:36 AM
The stud wasn't level with the top of the nut?
Old 01-12-2010, 12:17 PM
I measuer them and they were 1/4" londer then the old ones.
Layson. The stud was about 3/8" out of the nut, had to take about 1/8" off to get it to clear the ujoint knockle.
Old 01-12-2010, 12:33 PM
Yep there ya go, just a tad bit longer. So can you even put the grease fitting on there?
