911 Ccv Mod You Must Read!!!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-02-2007, 06:29 PM Thread Starter
Desert Shield/Storm Vet
vitalidle's Avatar
Here is the link to my writeup yesterday. I am sending this out so you will be informed about the problem I have encountered with my setup! I hope nobody has gone out and bought this yet till I can do somemore testing! Jegs Crank Case Ventilation Filter
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #2 of 7 Old 04-02-2007, 07:25 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
What is the problem with it? To much pressre??
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 7 Old 04-03-2007, 03:14 AM Thread Starter
vitalidle's Avatar
Sorry I actually put what I think might be the reason in the write up! I can't be sure till I look at it today, but until I find out what is causing my blowby I wanted to let people know not to go ahead with this till we figure this one out Here is what I wrote: Don't do this mod the way I did it until I do further testing!!!!!! I am having oil blowby through my turbo and I think its caused by this mod. This has been driving me nuts the last 24 hours. I for the life of me know I put the turbo together right. Its not rocket science, so I did some searching and found this:
The turbocharger “seals” play a secondary role in turbocharger oil control since the oil slingers are designed to prevent oil from reaching the seal areas. The primary role of the turbocharger seals is to prevent external gases (i.e., boost pressure and/or exhaust gas) from entering the center housing. Under most operating conditions in a blow-thru configuration, the gas pressures in the compressor and turbine housings are equal to or greater than the gas pressure in the turbocharger center housing (i.e., engine breather pressure). In this configuration, the pressure on the turbocharger seals is from the outside toward the inside and is actually trying to push any oil near the seal areas into the turbo.
If the engine breather system has been modified so that the engine crankcase cannot breathe and is causing excess crankcase pressure, this pressure is transmitted to the turbocharger center housing via the oil drain tube. In this situation, the crankcase pressure in the turbo center housing may exceed the compressor and/or turbine housing pressure; therefore, the pressure on the turbocharger seals is from the inside toward the outside and the crankcase pressure will push oil out of the center housing into the compressor and turbine housings. Excess crankcase pressure may be caused by engine breather modifications such as improperly installed performance breathers/catch cans or by worn or damaged engine components (i.e., pistons, rings, or cylinder walls) that result in severe combustion gas blow-by that pressurizes the engine crankcase and turbocharger center housing.
The only thing I can figure is by reducing the outlet side of the doghouse from 1/2 inch id to 3/8 and running it through the jegs filter is restricting it too much and causing to much back pressure. I am going to remove the hose in the am and see if my blowby changes. I am sorry for posting this and not testing it enough first. I hope I caught this soon enough before someone buys the filter and uses my writeup. I will do more testing tomorrow and get back with my findings!
Auto 93,000 miles
DP Tuner F5
post #4 of 7 Old 04-03-2007, 03:28 AM
It sounds like the same effect as replacing your stock 3.5" exhaust with a new 2.5" unit. Guzzle actually took some pressure readings before and after he installed his design. It seemed like he was worried about something like this happening.
I hate to see this not work! I have been hoping for a solution that more or less involved an inline filter to just seperate the oil and allow the system to work as originally designed.
720Deere is offline
post #5 of 7 Old 04-03-2007, 08:10 AM Thread Starter
vitalidle's Avatar
I unhooked the 3/8 hose and reducer from the doghouse and no more smoke. So my setup is causing too much back pressure. Im going to try some different combinations this week and see if the filter is going to be usable or not!
Auto 93,000 miles
DP Tuner F5
post #6 of 7 Old 04-03-2007, 10:54 AM
Quoted: 5 Post(s)
That sucks man. Hopefully you'll get something figured out!
John Wayne
REDNECK VALDEZ
You can find me on
post #7 of 7 Old 04-06-2007, 01:14 PM
guzzle's Avatar
Originally Posted by 720Deere View Post
.........Guzzle actually took some pressure readings before and after he installed his design. It seemed like he was worried about something like this happening..........
Yep, and still not real comfortable with it.
Last summer after pulling the boat back across the divide from Lake Powell and parking the truck in the garage, I had a few drops of oil on the floor, dripping from the starter. Figured it was the pedestal o-rings starting to go. It wasn't bad so I orders some new o-rings. By the time they showed up, the leak stopped.
Running around empty, not much load does not seem to be a problem but hard running, towing a load, I may be pushing it through a seal somewhere. Pedestal o-rings don't fix themselves and I still have not found where the leak was.
I am still contemplating a new design.
02 F350 4x4 SRW EC LB Lariat
guzzle is offline
