High Idle? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-11-2010, 06:15 AM Thread Starter
johnpaulgolf's Avatar
High Idle?
Do we have a stock mini-high idle???
Just curious cuz that last few mornings I have idled my truck and then when I get in and hit the brakes it drops from around 1000rpm back down to 700-800 or whatever the normal idle is ... just curious ... I've only had this truck a few months and was just curious if the Previous owner might had something in there not stock
2000 F350 Lariat 4x4 CrewCab Long Bed Auto
1969 Bronco RockCrawler
johnpaulgolf is offline
post #2 of 7 Old 01-11-2010, 06:42 AM
tubular031's Avatar
when its colder out the truck will idle up to help warm up. during this time you probably heard some hissing too. that is the exhaust bypass valve on the exit of the turbo closing to help warm up.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #3 of 7 Old 01-11-2010, 06:46 AM Thread Starter
Okay ... thanks for the response ... I wuz just curious ... still trying to figure out what the previous owner has done ... I have figured out that he (PO) has not done alot of maintenance and have had a few things needing to be fixed ... but all in all I LOVE MY TRUCK
post #4 of 7 Old 01-11-2010, 06:50 AM
tubular031's Avatar
The first thing you should with ANY new toy is change all the fluids and filters.
I would also change the coolant to a EC-1 rated coolant. I am goingto do this as soon as it warms up a bit.
post #5 of 7 Old 01-11-2010, 06:55 AM Thread Starter
I've done all of that and then some ... I have had the truck for around 4-5 months ... I've also done front brakes, water pump, zoodad, napa filter, foil delete, water fuel seperator o-rings, and cleaned and cleaned and cleaned and cleaned and and and and and and and did I mention I LUVS MY TRUCK
post #6 of 7 Old 01-27-2010, 07:46 PM
Flooringit's Avatar
Quoted: 33 Post(s)
So why do people do the foil delete? Is it just for looks or is there another purpose I've been looking for the answer but haven't found it
Flooringit is offline
post #7 of 7 Old 01-27-2010, 08:09 PM
F250 Fever's Avatar
Send a message via Yahoo to F250 Fever
looks, and a lil louder bout it.
2000 7.3 F250 FX4 ext cab short box
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
4in down pipe to a 5in tip
KnN intake
Tuned by PHP
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Diablo predator programmer (used for pulling codes)
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
F250 Fever is offline
