AIH delete - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-02-2007, 10:34 AM Thread Starter
Fishing Fanatic
kefier2001's Avatar
AIH delete
Well while I am waiting on my new turbo I dediced to go ahead and delete my AIH. I have the plug for the hole, and the dummy cable (wire) from DFUSER to keep codes from getting thrown, but I don't have the instructions on where to hook it up to, and Dfuser website seems to be down. Anyone have a write up on that one??? Thanks. I will also be deleting the EPBV. Do I need to hook the acutator arm back up?? I am gonna just grind off the rivets that hold the butterfly on and take it off that way, since turbo is out. And leave the shaft. Kinda cheating but seems alot easier.
2001 Ford F-350 Crew Cab 4X4
7.3L w/Built-up A/T w/billet Torque Conv.
4 inch SkyJacker lift w/35 inch AT's on Weld Wheels
Diablo Sport Predator Programmer
40,60,85, and tires gone!!(100hp)
4inch Farmboy Exhaust (No Muffler
), 10K Mod, Dfuser TC Lock-up Mod,
AIH and EBPV delete, MAP fooler,Glow Shift Gauges (EGT, Boost, Tranny)
Zoodad and Tymar DIY intake, CCV re-routed
More to come
kefier2001 is offline
post #2 of 5 Old 04-02-2007, 01:08 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Here is a good writeup for deleting your ebpv. http://www.blackclouddiesel.com/Tech...ting%20EBV.pdf Also here is some info on the aih delete. http://www.blackclouddiesel.com/Tech...2004-05-02.pdf
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 5 Old 04-02-2007, 05:45 PM Thread Starter
Fishing Fanatic
kefier2001's Avatar
Thanks, that is what I was looking for!!!!
More to come
post #4 of 5 Old 04-02-2007, 05:48 PM
vitalidle's Avatar
You bet! Here is the link to the code eliminator from dfuser http://www.dfuser.com/Install%20Guid...2004-12-27.pdf
Auto 93,000 miles
DP Tuner F5
post #5 of 5 Old 04-02-2007, 06:46 PM
CSIPSD's Avatar
I bought the stupit "code eleminator" for the AIH... LOL what a waste of money. Doesnt work and the dumb code doesnt hurt a thing.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
