lIFT HELP - Ford Powerstroke Diesel Forum
Old 04-02-2007, 07:37 AM
lIFT HELP
Hey all, I bought a 8.5 in pro comp lift its all spring 6 in im just not sure if I want to block the rear to equal the 8.5 or just put the 6 in springs on what do you guys suggest?
Old 04-02-2007, 04:24 PM
what size tires are you going to run. 37s will be fine with the 6 inch springs but for 38s you going to want to add the rest.
you will also need to do some driveshaft mods with the 8.5
Old 04-02-2007, 04:29 PM
International Threat
I'll tell you from experience the less # and the least amount of inches you can get by with in the rear that better the ride will be!
Old 04-02-2007, 05:24 PM
but that mainly applys to the spring brand aswell some ride way better than others. you get what you pay for.
shocks make a huge diffrence as well.
if it is a crew cab or long box ,traction bars may be needed and the 2 peice driveshaft will need to be shimmed but a 1 peice is better.
