Starter going out maybe?
I was cranking away trying to start the truck this morning and it cranked and cranked and cranked then grind grind. I stop. then I turn the key. crank for about a second then grind grind. Again turn the key crank for a sec then grind grind. After about the 3rd or 4th time It cranked and fired. I let it run on high idle with the ebpv closed and turned it off at 125 EOT. I tried to start it again, and the same as above happened again.
Need a new starter maybe? What is involved in replacing the starter? I remember reading that the DB (I think it was called) is a good one? |
Is there any chance you would be able to make a video? I'm having a somewhat similar problem and I'm curious if yours sounds the same as mine.
Sorry for not helping lol I'm not too knowledgeable yet |
Fellas it maybe a starter but it sounds more like a flywheel to me. I had this happen in an older truck. Most V8s will stop in one of 4 places. Over time the flywheel will start to wear in the spots. A new starter might get you by for a while but my guess is that if you find a place where it grinds. The stop and take the starter out and look at the teeth of the flywheel they will look chewed up.
yep, broken tooth/teeth on flywheel is sounding about right
oh crap dont say that. I hope its just the starter. fingers crossed
I would vote starter. Mine did that when it was going bad. The bendix would not actuate fully and it would grind on the flywheel. new starter and problem gone...
I would highly recommend a starter from DB. That is where I got mine. Much cheaper than ford and local parts houses and alot mor torque than the starter that came off (when it would work )http://www.dbelectrical.com/ |
I ordered the DB starter sat morning. I hope that Fixes my issue. No time or money to take it into get a new flywheel!
keep us informed.
