Help me identify an axle - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-08-2010, 10:18 AM Thread Starter
Looking to buy a front axle from someone, just want to confirm this is a dana 60. Here is the info the seller gave me: Came out of a 2002 F250, gear ratio is 3.73...here is a picture he sent me:
Looks like a 60 to me, but dont the dana 50's look just like them? What else should i look for here? Im used to dana 30's and 8.8's....
thanks guys..
2006 F350 Lariat, Turbo Diesel...Alpine Headunit, jl audio fronts, BA rears, 2 amps, subs coming soon
JeepAddict85 is offline
post #2 of 17 Old 01-08-2010, 10:30 AM
swamp_ratt's Avatar
more than likely a dana 50! you would need to look for numbers around the diff housing! there are a few spots on the housing that have numbers, one number should either be a 50 or a 60! that will tell ya what you buying! but im 80% shure the F250s had the Dana 50
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #3 of 17 Old 01-08-2010, 12:22 PM Thread Starter
The dude says it is a 60 but i want to make sure. i will research some more on the ID numbers on the axles. thanks
post #4 of 17 Old 01-08-2010, 12:33 PM
shaking things up
jethro's Avatar
looks like a 60 to me but idk for sure
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #5 of 17 Old 01-08-2010, 01:05 PM
swamp_ratt's Avatar
from what i understand, the 50s and 60s look really similar. only difference is pinion shaft diameter and axle shaft diameter and spline count i believe
post #6 of 17 Old 01-08-2010, 01:43 PM
shaking things up
jethro's Avatar
i thought the 50 was TTB? or was another number assigned to them?
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #7 of 17 Old 01-08-2010, 01:57 PM
97Beast's Avatar
Quoted: 13 Post(s)
From 99-to mid 02 f250s came with a solid Dana 50, but somewhere in 2002 Ford decided to put the Dana 60 under f250s.
John
'97-F-250 PSD CCSB 3.55s E40D, Dana 60, PMF 2.25" RSK, U Code SD Springs, 315/75/16 TerraGrapplers, Tow Mirrors, Colibert Tow hooks, RDS Stage 1s, PHP 80hp, RiffRaff 6637, 3"DP, 4" Exhaust, 6" Tip, Power Front Seats, Rear 40/20/40, Explorer OHC and Autolamp Rearview, EATC, Cree LEDs & more
'89-Bronco 5.0l 33"s Free flowing exhaust, 06 SD power seats, & more (SOLD)
'80-M35A2 "Deuce 'n a Half" W/winch Multifuel Soft top
97Beast is offline
post #8 of 17 Old 01-08-2010, 02:16 PM
shaking things up
jethro's Avatar
ok wasn't TTB also called the dana 50?
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #9 of 17 Old 01-08-2010, 04:10 PM
97Beast's Avatar
Quoted: 13 Post(s)
Yes it was. I'm not sure why they both had the same number but the ttb is also known as the D50.
John
97Beast is offline
post #10 of 17 Old 01-08-2010, 04:11 PM
shaking things up
jethro's Avatar
ok good so i am not nuts lol
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
