ebp sensor
The exhaust back pressure sensor thats in front of the motor, with the tube to the pass side manifold, whats it do?
I have read how to clean it. How would you know if you need to? |
anyone??????
im not sure if you have read the others posts recently about this but you can notice worse fuel mileage or it can throw engine codes if its bad enough or it can make your trck sound like a jet engine taking off which is what mine sounded like but just assumed it was normal cause i just bought the truck a little over a year ago and thats how it sounded since i bought it. but my truck has a 165k on it and just read about this problem the other day and pulled mine off and the sensor and bracket nut assembly was almost completely plugged up. i have heard its a good idea to take it and the tube off twice a year to clean it so you dont have any problems with it so thats what im going by
Its designed to help warm the engine up faster, by putting a load on it.
Speaking of, I need to clean mine tomorrow
Make sure you don't snap it off when you put it back on either. That was an expensive mistake I made.
Generally, my experience is that it won't close the valve on COLD startup. I took my EBPV out, but when it was still in my line was plugged and didn't think it was causing any problems (which it really wasn't other than longer warm up times) until I borrowed my buddies truck and heard his "jet engine" at warm up. Almost freaked me out for a minute until I realizeed what it was.
It basically sends the backpressure to the computer so it knows how far it wants to close the valve...at least that is my understanding. Quote:
I got lucky and they warrantied it for me so just a big PITA. I'm very careful these days...lol.-Aaron |
dont want to steal the thread...but if i take the ebv tube off, clean it, and take the sensor out and clean it, it will take the jet engine noise away when cold?? mine does it for along time when its cold. getting annoying ahah
-Aaron |
