1211 and shakin at idle, hard to start
So im throwing a code 1211, and my truck sucks to start and shakes like crazy when it does. The ford tech told me it is the ipr and its showing low pressure,causing it to be hard to start also. So do you guys agree.
could be IPR, faulty ICP sensor, could be leak in HPOP system, 1211 code needs some diagnosis
1211 is set if ICP is 400 ish psi above or 275ish psi below desired pressure for about 7 seconds would like to see the duty cycles % of the IPR, did they live scan the truck? Last edited by ianstew; 01-07-2010 at 01:39 PM. |
no they didn't do a live scan but it showed 1211 and low oil pressure. And the hpop isn't leaking
it could be just the IPR, but IMHO i'd hate to throw a 200 part on it without knowing a little more
Yea very true, the truck has 230,000 on it. And the abs isn't working either come to find out its a 780. abs control module. Luckily a good friend works there and can get both for 525.
pull the plug on the icp sensor and see if theres oil down in there. if there is the icp sensor is going bad. just went and had to replace mine
which plug are u talking about. the end plug I guess
First time workin on this part of the engine
They leak internally.
Pop your hood, look straight that the truck, on the front of the DS head there will be a plug with a purple seal-thingy on it. Check that. |
thanks for descibeing that austinj i brain farted when i typed that
here a link to a pic in the repair section 99-03 7.3l engine sensor locations Last edited by highraven99; 01-08-2010 at 01:39 AM. |
