Looking to buy a Scan tool! - Ford Powerstroke Diesel Forum
Old 01-07-2010, 05:42 AM
Hey everyone, I am looking to buy a Scanner to use on my F250 and F550 with the 2002 7.3L.
I was looking for some advice on which scanner some of you would recommend. I would like to purchase one that will also work on the 6.0L and 6.4L diesel and possibley Gassers as well if possible?
I want one that can run the buzz test and all that stuff. I already have a superchip code reader, but thats all it does is read codes and clear them.
Old 01-07-2010, 05:59 AM
scuffs *****
Send a message via AIM to Tyler
The SCT Tuner is a great code puller, also you can try Auto Engenuity, or OBDCOM.
Old 01-07-2010, 06:22 AM
For the money, auto enginuity is the best as long as you have a laptop to run it. It will do buzz tests and even test the gp system. Works on all OBDII systems.
Old 01-07-2010, 06:41 AM
With the SCT Livewire for the 6.0 diesels, can I use it to read a code on someone else's 6.0 without using an unlock? I just want to pull the code and nothing else. Also do I have to set my truck back to the stock program to do it? Thanks for the info.
Old 01-07-2010, 07:03 AM
scuffs *****
Not sure about that, but the XCAL3 will read codes off anything.
Old 01-07-2010, 07:14 AM
Tyler, or anyone else
I have an xcal 3 for my mustang gt, do I have to set the car back to stock as well as will it take away an unlock off of the programmer? thanks.
Old 01-07-2010, 07:16 AM
scuffs *****
No, you shouldn't have too, just plug your xcal into the truck, and click on Check Engine, and READ DTC... should work. I just used ours on my buddies truck this morning.
Old 01-07-2010, 07:38 AM
Thanks I will try that.
Old 01-07-2010, 08:35 AM
Scan tool software
Will the AutoEnginuity software for the laptop work like the Snap-on Solus scan tool? Will it tell me if i have a bad injector, or bad ICM, which injector it is and all that stuff?
Old 01-07-2010, 08:38 AM
scuffs *****
I'm not to sure about that software, but I think it will tell you which injectors fail the buzz tests.
