Removing fan assy. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-06-2010, 11:18 AM Thread Starter
Fred Swanson's Avatar
Removing fan assy.
Does anyone have a trick or method they use to hold the water pump pulley when turning the large fan nut when removing the fan? I will be using a Matco type removing wrench that uses a air chisel to loosen the nut but in the past I have had to try to hold the pulley because even with the belt still on it wants to turn when getting the nut loose, Thanks, Fred
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #2 of 10 Old 01-06-2010, 11:27 AM
International Threat
Marty's Avatar
Use a Fan Clutch wrench on the 4 bolts on the water pump pulley, then use a big pipe wrench on the fan nut itself. It's standard right hand thread. Having a friend hold the fan clutch wrench helps out a lot.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 10 Old 01-06-2010, 03:06 PM Thread Starter
Thanks Marty!
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
post #4 of 10 Old 01-06-2010, 06:05 PM Thread Starter
This particular wrench only fits the large nut and has nothing to hold the pulley nuts with....maybe it will bust loose without holding the pulley seperately......if I'm lucky......Fred
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
post #5 of 10 Old 01-06-2010, 06:41 PM
I usually tap the big fan nut with a hammer prior to trying to break it loose. It has never failed me. Also put a box end wrench on one of the pulley bolts and hold with one hand while pushing with the other....Its a pain in the ars!
tex_waco_usmc is offline
post #6 of 10 Old 01-06-2010, 07:44 PM
At least you are working on a pickup truck. The vans don't even have enough room to get 2 tools in there at the same time, the fan clutch shaft is about 1.5" shorter.
I think that the tool the original poster is using should have come with a holding wrench as well as the wrench for the actual clutch.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #7 of 10 Old 01-06-2010, 08:06 PM
Marty's Avatar
Autozone or Advance will have a clutch tool you can rent. You get your money back after you return it.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #8 of 10 Old 01-06-2010, 08:26 PM
Big Papa 03 dually's Avatar
I always put an old belt around the pulley, then have someone pull on the belt, if it goes at least 3/4 the way around it will hold the hub. But you have to hold it tight
Big Papa 03 dually is offline
post #9 of 10 Old 01-06-2010, 08:36 PM
Powerstroke Techie
forddieseldoctor's Avatar
If you have the one that uses the air chisel you will just have to keep your belt on and tight. They work slicker than $hit. I love mine. I use it on anything that it fits.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #10 of 10 Old 01-07-2010, 07:58 AM Thread Starter
I had to end up putting a large screwdriver between one of the pulley bolts and fan collar and hit with the air chisel/Mac wrench removing it....it would still spin with the belt on and no retaining of the pulley....came loose instantly after retaining the pulley.....Thanks to all for your suggestions, Fred
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
