Trans Temp Guage - Ford Powerstroke Diesel Forum
Old 01-06-2010, 09:28 AM
Trans Temp Guage
Just installed one on my truck. It never registers on the guage. It always stays below 100 deg. I usually dont drive over 50 mi or so.... is that not enough to heat it up?
Old 01-06-2010, 10:33 AM
Depends on how cold it is, if it's in town or highway, load and driving style. I have about a 10mi commute and when it's 30-40° as it has been lately, I don't see any movement. You could also have a bad connection, probably ground.
Old 01-06-2010, 02:03 PM
Send a message via Yahoo to F250 Fever
mine dont even move maybe a tick jus depends on the temp though, should be around 70-90 above ambient temps.
Old 01-07-2010, 04:20 AM
Powerstroke Junkie
I just made the same reply yesterday. Average trans temps are 70-90 above ambient, the lower while unloaded and the upper when towing heavy. Mine won't move again until spring. It also takes 20-30 min of driving to heat up almost 5 gallons of trans fluid. It will not hurt anything not to let it warm up all the way.
Old 01-07-2010, 06:57 AM
Alrigh thanks.... I was thinking I might have gotten a bad guage or something. Thanks for all the help.
