low batts tranny no working
hi when i try to start my f250 00 7.3 diseel the batteries low i cant start the engine i try with small battery n jump with another car the car start after 3 times to start the engine. but now i cant move the car n,d,1.2 same no engage the tranny what do you think?
sorry poor english
when you put it in gear.... any of them does it still seem like its in park.....
just get some revs maybe up the revs 200 thats all when i push the aceletarator no engage the tranmission...........
the oil of tranny i need check when the engine is working or? |
have you checked the fluid yet..... is it dirty or smell burnt
yes i check the fluid i have question i need check the fluid when the engine is working? or no working
when its running is when you need to check the level..... and the color and the smell...... anything abnormal.... did you pull any trouble codes from the computer
i check the level they need 1 quarter of oil now its ok the level
i dont use mecron oil i GET chevron ATf
o ok..... i use the same thing you use..... go to a local auto parts store like autozone or checker and ask the to pull some codes off your truck..... if that doesnt work which it prolly will.... then go to a shop and have them run a diagnostic test
I TRY TO run the car again tomorrow maybe the tranny works the car dont have check engine light on can i check the codes with odb2? scanner? where is the socket
