removing rear door panels
i just replaced my front speakers without a hitch and i opened up the back doors and i didnt see a obvious way to remove the panels
its a extended cab not a supercab with the pop open windows can someone explain how to remove these panels really quick so i can change my rear speakers |
Hmm not sure just looked at mine. I will take a better look at it tomorrow and see what it takes. If you figure it out in the meantime post it up, as I need to change out my speakers also
i got the top piece off just unscrew the window prop and unsnap now im stuck at what to do with the rest of it
i removed 2 7mm bolts holding the plastic and now i dont know how to remove anything further |
Let me scour the internet and see what I can come up with. I have some great pics for the front door panels, but nothing for the rear.
it appears the arm rest portion should pop right out
then you lift up on whats left of it and that should come off as one piece if feels as if somethings holding it back |
Here is some good info for anyone else on the front door panelsDoor panel removal
Steps to removing rear door panel on a extended cab no supercab
1. pop off top piece slip your finger behind it and pull it pops out easy 2. remove 2 7mm nuts 3. remove 2 pop fasteners 4. lift up on door panel it looks alot more complicated then it is |
Sweet Thanks! I will be doing this in the not too distant future!
just remove the 2 screws on the glass latch
pull top surround off (snaps in place) remove two screws and the 2 push pins buy pushing in the center of the pin slightly remove the push pins and lift on the panel. |
