Gauge Bulbs - Ford Powerstroke Diesel Forum
Old 03-27-2007, 05:38 PM
Gauge Bulbs
Hi i have autometer gauges. The bulbs in them are dim and i would like some brighter bulbs. I have been looking on ebay. I am wonderiing will the 194 base led bulbs work in my autometer z series they are cheaper that is y i am looking at them thanks
Old 03-27-2007, 05:54 PM
i have the same problem, but only the egt guage is dim. I can read my boost guage perfectly. i.t.p., and dfuser sell some l.e.d. replacements
Old 03-28-2007, 07:06 AM
Get the one's from ITP...
Old 03-28-2007, 08:31 AM
PIPE HITTER
The 194's will work, I had the same problem.....
Old 03-28-2007, 08:34 AM
I was told by Autometer that you don't want to go any higher than a 168
Try an automotive replacement bulb number 168. That would be the
brightest that you want to use. Also measure the voltage at the white
wire on the gauge to be sure that you have available a full 12 volts
with the lights on and engine running.
Thank you.
Cory
Tech/Service
I agree that Z series gauges need more light
Old 03-28-2007, 08:36 AM
How long have you been using a 194? The 168 is an improvement, but it's still not quite bright enough
Old 03-28-2007, 08:49 AM
PIPE HITTER
For about a year or so, no problems at all.
Old 03-28-2007, 09:11 AM
Thank you!
Old 03-28-2007, 09:38 AM
Send a message via AIM to purduefarmboy460
so, 194 LEDs will work too?
Old 03-28-2007, 09:48 AM
I just emailed Cory @ Autometer about using the 194 bulb.
His reply:
Your gauge may already be equipped with a 194 bulb. The 168 is
brighter.
Thank you.
Cory
Tech/Service
