map fooler question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-27-2007, 04:15 PM Thread Starter
red73psd's Avatar
map fooler question
alright i beleive my boost gauge is only reading up to 17psi but my truck is making more cuz it will make it there without coming close to flooring it and it will get there on all hp setting's how do i get around this or where do i start to look for any kind of answer..... i saw something on here awhile go about the same thing i cant find it though any help is appreciated
2010 DODGE 3/4 CUMMINS 6 SPEED MANUAL 4X4
(SOLD)2006 dodge 2500 cummins 4x4 6 speed full 5 inch strait pipe brute force intake edgejuice with att. hot unlock. sbc 3250 dd clutch weighted powder coated shift knobs dc mud country tires and a leveling kit smarty 2nd gen exhaust manifold and htt 62 65 12
441hp 920tq
red73psd is offline
post #2 of 16 Old 03-27-2007, 04:46 PM
Lord Tauk's Avatar
Throwing out an idea;
Could it be a leak somewhere? Where is the gauge getting it's reading from? I assume you're supposed to get the SES light for a few mins after the motor defuels
With the WW and the housing, plus the highest HP setting on the chip I'd assume you would definently see over 20.
Lord Tauk is offline
post #3 of 16 Old 03-27-2007, 06:01 PM Thread Starter
red73psd's Avatar
ya i no i should be i mean unless the turbine on the exsaust side of the turbo is messed up or maybe it is clogged or something.... but i have the map fooler so my ses light doesnt come on but somewhere i heard (beleive it was here) that your gauge will only reader as much as your map sensor will allow it and i beleive it on reads up to like 20 or somthing close to that
441hp 920tq
red73psd is offline
post #4 of 16 Old 03-27-2007, 06:42 PM
bryanbrown's Avatar
where is your guage hooked up? if your guage is be in front of the map sensor, it will read the actual pressure. what kind of fooler do you have? have you unhooked you wastegate? there is a BIG difference in mine if it is unhooked.
'01 F350 2wd Lariat Dually 7.3 6sp-back to stock
'06 Dodge 4wd Dually, Auto, Edge Juice, AFE Bladerunner, 5" turbo back, BHAF
****SELLING ALL MY STUFF**NEARLY ALL GONE**PM IF INTERESTED IN ANYTHING***
Spearco 6.0 Retrofit I.C.- $800 shipped
coated uppipes(not bellowed)- $200 shipped
bryanbrown is offline
post #5 of 16 Old 03-27-2007, 09:38 PM Thread Starter
red73psd's Avatar
not sure what kind is is just bought it under the table at a performance shop and thats it...... it works though
441hp 920tq
red73psd is offline
post #6 of 16 Old 03-27-2007, 10:30 PM
lilredpowerstroke's Avatar
Is it electrical or mechanical fooler??
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #7 of 16 Old 03-27-2007, 11:12 PM Thread Starter
red73psd's Avatar
mechnical fooler
441hp 920tq
red73psd is offline
post #8 of 16 Old 03-28-2007, 05:30 AM
Waist Gate
When You Say Unhook The Waist Gate Do You Mean Take The Rod Off
Or Plug The Vacuum Line. ? And Will It Over Bosst Or Cause Damage If The Rod Is Unhooked ?
POWERSTROKER2000 is offline
post #9 of 16 Old 03-28-2007, 06:12 AM
do yerself a favor and check yer whole air system for leaks,,,,,,,,,,I built a tester to clamp to the charger inlet then used some shop air to check for leaks.............I have done prolly 30 trucks now and everyone on them had boost leaks including my own.
Cheers,Kevin
Whitmore is offline
post #10 of 16 Old 03-28-2007, 06:43 AM
straycat's Avatar
I'm thinking it's your boost fooler, it is only letting the map see so much boost, and thats what the gauge is showing.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
