Soot on all intake to intercooler boots - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-22-2009, 07:27 AM Thread Starter
Fred Swanson's Avatar
I have soot on all of my intake to intercooler boots even the ones all the way in the front where they connect to the intercooler....you would think those wouldn't be as prone to being sooty away from the actual engine....probably my sign to change all...where is the best place to get replacements? Thanks, Fred
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #2 of 11 Old 12-22-2009, 07:34 AM
GoldieStroker944's Avatar
well it sounds like its not soot??? its probably oil because the crankcase vents in there mine are all covered in oil right now
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #3 of 11 Old 12-22-2009, 10:53 AM
I am not sure for the build up on the boots but you do not need to replace them. Just wipe them clean and/ or use simple green, do not use carb cleaner it will eat at the rubbber. every diesel has some road grim and or soot build up.
bashlin1 is offline
post #4 of 11 Old 12-22-2009, 11:48 AM
Powerstroke Junkie
NCHornet's Avatar
It's not soot, it is oil that collects from the CCV and it saturates the boots and will eventually cause them to leak. That is why every PSD should have the CCV mod done and done the right way. You can clean them, but sometimes it is hard to get them to reseal and they will blow under high boost scenarios and scare the heck out of you. Here you go, PM me with any ?
CCV Mod
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #5 of 11 Old 12-22-2009, 04:51 PM
F250 Fever's Avatar
Send a message via Yahoo to F250 Fever
CCV Mod
What's the ccv mod?
2000 7.3 F250 FX4 ext cab short box
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
4in down pipe to a 5in tip
KnN intake
Tuned by PHP
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Diablo predator programmer (used for pulling codes)
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
F250 Fever is offline
post #6 of 11 Old 12-22-2009, 05:38 PM
Cjcross22's Avatar
That link gives a lot of info on it
-Cory
Y2K
F250 XLT 7.3L ECSB SRW ZF6 4x4
Cjcross22 is offline
post #7 of 11 Old 12-22-2009, 05:56 PM
F250 Fever's Avatar
Sry I'm an idiot. Didn't see the link I'm lookin at this on my phone lol
KnN intake
Tuned by PHP
6in Pro comp lift
Foil delete
ATS Turbo housing
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
post #8 of 11 Old 12-22-2009, 05:57 PM
Cjcross22's Avatar
lol all good i had to go check it out as well
-Cory
Y2K
post #9 of 11 Old 12-22-2009, 06:04 PM Thread Starter
Now what is the AIH delete?...Thanks, Fred
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
post #10 of 11 Old 12-22-2009, 06:08 PM
Cjcross22's Avatar
Info and pics here AIH Delete
-Cory
Y2K
