Driveshaft Swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2007, 11:20 AM Thread Starter
PIPE HITTER
gcop's Avatar
Driveshaft Swap
hey guys I have an 2000 Ex 4wd that about to get a lift, I also have a 99.5 F-350 2wd thats a work truck. I was thinking of swapping the driveshafts if possible, so I can shim the Ex if I need to, the 99.5 will never be any higher off the ground than it is right now. I figured simce they are both 350's it wouldn't be a problem, but I'm not 100% sure.
"Life is hard, it's even harder when you are stupid"
gcop is offline
post #2 of 6 Old 03-27-2007, 03:05 PM Thread Starter
PIPE HITTER
gcop's Avatar
bump
gcop is offline
post #3 of 6 Old 03-27-2007, 09:50 PM
lilredpowerstroke's Avatar
How much lift are you getting.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #4 of 6 Old 03-28-2007, 08:33 AM Thread Starter
PIPE HITTER
gcop's Avatar
Not much TJ just a 4" I know that I will most likely not need to shim the driveshaft, but, while it's on the lift, I figured what the hell..
gcop is offline
post #5 of 6 Old 03-28-2007, 08:57 AM
I would rather have a one piece driveshaft IMHO. A 4" lift shouldnt really shoudnt affect the the angles that much. If it does you can get degree'd shims to put between the spring and axle to get the angles better.
T.J.
Centennial Edition
post #6 of 6 Old 03-28-2007, 10:03 AM Thread Starter
PIPE HITTER
gcop's Avatar
cool, thanks.
gcop is offline
