Boost Gauge hole location?
Where do I drill the sender type hole for the boost gauge? seems like somewhere in the Y pipe from what I can tell from pictures but where is the best place for it? also same question about the egt sender/probe hole.... Thanks, Fred
u can buy a AIH delete plug with the hole already in it, and for egt probe u want it in the driver side exhaust manifold right before the uppipe
Took the words right out of my mouth. |
Or you can drill and tap it yourself, install it in the map line, or weld in a bung in one of the I/C tubes.
Just use a T and put it in the mapline, easiest and done in 5 min. As for the EGT probe you want it in the exhaust manifold, drivers side, about 1 1/2 from the union to the up pipe. Crawl under the front of the engine and you will be staring at it.
Whatever you do dont take the easy way out and mount it in the downpipe.
Just put it in the MAP sensor line
