3800$ later
well my baby has been in the shop and come to find out my tranny is near failure......... so im having some gas tank seals replaced oil leak fixed and a complete stock4r100 rebuild with performance torque converter not sure what brand yet........ but tell me if this is a good deal $3800 parts and labor fluids and flush also includes gas tank seals and labor and oil leak
E40D 6 Pinion steel rear planetary E40d 4 Pinion steel overdrive planetary E40d 6 Pinion steel forward planetary Direct commercial friction kit Forward friction kit with hardened teeth Center support gasket 45 element sprag Modular line pressure assembly (.427) Triple disk maximizer diesel converter Master overhaul trans kit Valve body kit Mag-hyte pan hope this helps... |
thanks man hughes performance tc..... (local builder) or ats triple lock either one doesnt change the price...... as for the tranny complete stock ford rebuild..... with 3 year warrantee
Welcome to Hughes Performance! Last edited by red73psd; 03-26-2007 at 04:06 PM. |
-Raul |
i would like to do thatbut i dont have the funds ...... hopfully when im done with school i can get a better paying job then im not gonna stop with mods..... i have a whole list of stuff already
bump......
do you have a breakdown on what moneys going where?
only reason I ask is because an oil ieak can cost 5 dollars to repair yourself and I'm not sure exactly what it is your doing to the fuel tank but seeing how much is going there can help us figure out the "is this a good deal?" scenerio. |
well it was 2700 for a complete stock rebuild and then i had him upgrade the tc which is 1000 with a deal then hundered for the seals on the fuel tank then the oil leak was coming from the pipe right below the y pipe no charge
Dosen't seem too bad to me, but I agree with the shift kit.
Gord. |
Let them fix the oil leak, you fix the diesel or fuel tank and take the rest of the money and get a biult tranny from BTS or Suncoast or ATS. You will be alot happier in the end. BTS tranny is just under 4000 comes with 2 year unlimited miles unlimited horses.
