Batteries, Whats good?
my truck wouldnt start this morning, for the first time ever, batterys couldnt handel -2* so time for new batts. whats the best ones for the money?
I know I need at least 850cca right? I have ever starts in it now gonna see if they'll warante them but I doubt it. |
I run Motorcraft 850cca, they havent let me down yet
Go with the biggest (C-C-Amp) you can fit. I like to buy mine @ NAPA, because they will stand behind it without question. Other places might as well, but NAPA is close and I've always had great luck with NAPA batteries. The ones in my skidder are 4 years old, and it's never had an alternator...I just pull them and re-charge them every so often depending on the temps. All it does is start it, they last a good long while.
Also, the starter in my 550 went, and it acted for all the world like dead batteries...it would start better with a jump, but I replaced the batts and it started the same.. meaning barely. A new NAPA re-built has done me well the last year.. And plug your truck in..mine started this AM with no glow plugs just by being plugged in...makes a HUGE difference. BTW, I live about 35 miles north of you in Effingham NH. It was -6 here last night.. |
well just got back from wallyworld batts are almost 5 years old!
so no free replacement ![]() there on the charger now and truck's pluged in so hopefully I can get a few more days out of em till I can afford new ones
I don't believe the CCA #'s on some batteries. Consumer Reports had the Duralast Gold's as #1 and I bought them for $72 each. They lasted 1 day past the 3 year mark, after some arguing at Advance they gave me 2 new batteries, but I noticed they are now well over $100. No way!!! For that money ask for the Ford OEM battery, my stock ones lasted 6 years and they were 850CCA and the Gold's were 875 CCA, but they weren't nearly as good.
I just installed 2 1000 cca batteries. 1 is a deep cycle battery for super cold starts. Do yourself a favor though, about 3 weeks ago I replaced just 1 battery, the other said it was fine. A week ago I was driving down the road and BOOM, the battery I didnt replace blew up! Sounded like a bomb, scared the $hit out of me. They said because they are wired together the stronger battery was fine, but the alternator was trying to get the old battery up to where the new battery was, and it couldnt take it.
you dont "have" to change both at once, usually one follows the other but i did testing to the older one before just changing 1 and it was fine..its been 5 months now and not a single issue..both batteries read great and have no issues!
I kept with the Ford OEM batts, seriously there awesome..ive tried napa etc nothing seems to last as long! |
uh huh, both of mine read great to after I changed the one, and then kaboom. I talked to Battery Warehouse, who specialize in the field, and they said they should be changed at the same time. If you dont its up to you, its your truck, but I can tell you it was no fun taking out a blown up battery, and the fact that it ate the paint off the inside of my hood. Better safe than sorry. Look at it this way, you can take the chance and save yourself $100, but if it blows it could cost you way more in the long run, maybe even your life. I am thankful it didnt blow up in my face.
Optima red tops here.
when mine went i went with Motorcrafts. they were a little cheaper than the Dekas. was a toss up between the two
