Speedo Q?
i just noticed today that the speedo on my truck started to jump about 5 mph when going down the road. i took both batterys out last night when i installed some hid lights to mount the boxes on the side. is there any wires up around the batterys that i might have bumped. i did take a ground wire loose on the front driverside and put back on to intall one of the boxes. would this wire have anything to do with that. thanks for the help.
Was it on a smooth road or were you on a back road when it happened?
Would guess that it is a contact issue. Double check your battery terminals to make sure for good contact. |
smooth
i would say it was pretty smooth, i was on the highway for about 60 miles. if something was loose why would it just affect the speedo. is there is a wire up front that has to do with that.
I am suggesting the batteries since you removed them. Wierd things can happen when there is a bad/ not tight connection. It can make your truck shift funny, turn on/off turn signals, and surely effect your dash instruments.
Others will chime in on the issue for sure, but it is also the cheapest thing to check/fix if you have a connection issue with your battery. |
thanks
yea you are right i will check the connections. thanks
could be just bad timing and the VSS could be going south.
vss
when you said something about the vss are you talking about the part in the rear axle.
