HPOP questions. - Ford Powerstroke Diesel Forum
Old 12-18-2009, 04:30 AM
HPOP questions.
Hey all,
Another newbe question. When I start the truck, warm or cold, it cranks for about 5 to 15 seconds, and then starts up with no problems. On the guage cluster, the oil presure is nothing for about 3 seconds, then goes to normal.
does this sound like the HPOP not having oil in the reservoir? I have yet to go out and open the hpop to see if there is oil in there. There is a nut on top of the HPOP with a alan key, and I am going to guess that is to check the level. Also where is the check valve?
Thanks for the info. I just want to get all the info before I go outside and work on it. It is beging to get cold in Ohio, and I have not got my new winter gear so I might freeze to the truck!!!
Old 01-02-2010, 03:34 AM
Lifetime Member
The good level of oil also interests me also Thanks
Old 01-03-2010, 06:24 AM
Powerstroke Junkie
The gauge taking a few min to register is totally normal. Are you running a lighter weight oil? In the cold climates you should be running 10w-40 or 5w-40, it makes a huge difference!! If you want to check the HPOP level pull the plug on the right side of the top of the HPOP, the oil should be within a 1/2" of the bottom of the treads, 3/4-1" from the top of the HPOP housing.
Old 01-03-2010, 07:33 AM
Lifetime Member
Ok thank you for the levels.
I have just made my draining engine and Hpop.
The engine is much softer.
Thank you very much for the engine .
P.S. Oil Mobil Delvac 10-40 XHP Extra
Old 01-03-2010, 02:54 PM
hpop
Hey all,
thanks for the replies, my truck as a small leak, so I check it every time I start it, and it never gets below the add mark. it leaks aobut 2 qts a week.... I checked the plug on the hpop and it was towards "full" I checked it after running it for about 2 hours, and then let it set for about 2 hours. It sat over the weekend so I will check it again.
Thanks again,
