Correct water pump torque specs? - Ford Powerstroke Diesel Forum
Old 12-16-2009, 10:33 AM
So I've seen reference to some bad numbers in some of the repair manuals.
What are the correct torque values for the bolts?
TIA
Old 12-16-2009, 02:28 PM
Powerstroke Junkie
Water Pump and Thermostat bolts are only 18ft lbs, you go much more you will destroy the rubber O ring that seals the WP and break the bolt!!
Old 12-16-2009, 02:38 PM
and that my friend, really sucks bad when that happens.
Old 12-16-2009, 05:45 PM
Yep...that's why I wanted to check and make sure....BTDT broken bolt drill too many times LOL.
Thanks for the info!
