cutting a hole in a bumper - Ford Powerstroke Diesel Forum
Old 12-13-2009, 04:32 PM
I want to cut a 1-3/4 hole in a bumper? I need a hole saw. whats bi-metal mean? what tool do i need to get to do this with? It needs to be a clean cut(pretty much)
Old 12-13-2009, 04:38 PM
Bi-metal means there are two metals in the hole-saw bit. Usually the teeth are something harder then steel such as carbide, diamond, etc. I personally would just use a cordless drill. I also would put down some tape where you are going to drill so the shavings don't scratch your bumper.
Old 12-13-2009, 05:16 PM
Mind if I ask what you are cutting the hole for?
Old 12-13-2009, 05:19 PM
going to install my trailer tow plug thru it, just cause i want to
I am going to use my cordless drill, but you think a hole saw will do it?
Old 12-13-2009, 05:32 PM
Got it. A hole saw with fresh teeth yes.
Old 12-13-2009, 06:06 PM
i just bought an 08 bumper for my 01. same color. But theres a dent in it. In a great spot for the trailer tow plug. The 08 bumper does not use the same mounting bracket as my 01. i willkill 2 birds with one stone.
Old 12-14-2009, 05:06 AM
Powerstroke Junkie
You can rent a quality hole saw from most rental places. I borrowed mine from a local body shop when I did the Marinco Mod.
